FZJ80 wiring hell...
Dallas TX
So I've had a few misc electrical issues on new to me fzj80. Dug into a bit deeper today and wish I hadn't.. several electrical connectors in the drivers side relay box area that had jumpers on them, a few cut wires, one larger female connector completely no connected, and 1 male connector up by the mirror and dimmer not connected. Does anyone have, or have seen a simple diagram that at least shows what connector is doing what?
Check engine light was burned out. Now that it's changed, it's not going off. OBD2 wasn't pulling a code..
Any help is appreciated!
Not sure at all tbh.. I'll post some pics. It certainly didn't look professional. And most were just frayed and not connected. But now the blinkers don't work either lol. Oi!
Here is the 2 connectors I don't see connecting to anything. Also the jumpers were just all over. I removed several. The jumped wire that's still there was me reusing the jumpers for a wire that was too short to splice. Just a mess.
What year?
Get an electrical FSM for your truck and start tracing. Look for it on this forum.
Obviously you also have an aftermarket stereo......
Hi Smaddox this was useful for me when dealing with some aftermarket/dodgy wiring in the dash of my vehicle.
Bugger i cant upload word doc format. send a pm with your email and i will email it to you. its the wiring diagrams for the 80s
The black plug looks like the obd diagnostic port that should be mounted above the fuse panel.
Ive always wondered where that plug was located. DO you know if there are there cheap diagnostic machines that plug into these ie still available?
You can go to O'Reilly and check it for free.
Or you can buy an adapter on Amazon for OBD2 for about $25 and do it through your smart phone or you can get a ScanGauge or UltraGauge for about $100. (I have an UltraGauge)
Thanks all!
  • It's a 95. Bit of a misunderstanding on these years on here it seems. You hear that early 95s or more fj80 than fzj80. This is an 01/95, however it's also the OBD2/A343F.
  • I do know the black one is the OBD2. It's only got 4 pins in it. Wasn't sure if maybe one was pulled in an attempt to bypass a check engine code to pass emissions?
  • The harness/connector that seemed to be mangled to a concern level is the one with a jumper attached.
  • I've no idea on the 2 white connectors.. nothing attached, and can't locate anything else that match them.
O'Reilly's wasn't seeing any codes prior to me replacing the check engine bulb. But that was the day before. So I don't think it was coincidence, but not sure.
I also have an 01/95 OBDII and 343; must have rolled off the line together. I can post a couple of pictures of the wiring behind the kick panel for you. All of my EW is stock and works well (knock on wood). As far as a simple diagram, I haven't had trouble with the EWD, aside from putting it back together after I downloaded it from TIS. It's page numbered, and if you're patient and attentive you won't miss anything.
There's too much there to "simplify", IMHO. That area is a harness junction area; it was just a convenient place to put things for diagnostic and repair efforts at the dealerships. Not everything there "electrically" relates to a collocated wiring bundle.
Are you sure the spliced you're looking at aren't the dealer-installed alarm? A sloppy install is typical.
Mine was a s*** show in there with the dealer alarm and 90's era brick cell phone installs. Jumpers all over, and those same red splice connections. I was able to take it all the way back to factory, save for one wire jumper that I'm still chewing on replacing.
Pictures of your wiring in that area would be super helpful! After seeing so many of those jumpers, I started wondering if that was how it came from factory lol. Even have jumpers into the ignition harness..
