FZJ80 Radiator Dimension Question
Will Van
GOLD Star
Austin, TX
Could someone with a tape measure and a 1993 to 1997 radiator take a measurement for me?
What is the dimension from the bottom face of the bottom tank to the top face of the top tank? All the illustrations I have found only measure the core dimension.
I think it's about 22.25 inches.
Also, what radiator are you running (OEM? Aftermarket?)
TIA
21 5/8" or 55cm.
I have a broken TYC1918 sitting in my garage.
If anyone has an aluminum radiator (CSF, Liland, Mishimoto, Wizard, Griffin, etc) I would appreciate the same measurement from an aftermarket radiator as well.
Thanks!
How do you like the Liland so far? My OEM radiator is leaking only after 1 year of ownership, looking to try this one out.
Fitment was perfect
Welds are what I expected for a Chinese radiator, though they're better than mine cause I suck at aluminum
Transmission line fittings are threaded just like OEM for ease of install
It's been really cool out here so I can't attest to its cooling abilities but so far so good
Only changed it out because the bypass hose fitting on the radiator was almost completely broken off; my stock radiator was not leaking or having any other issues
The Liland variant should hold up better
