My '95 with a 3in slinky lift and 255/85R16s consistently pulls to the right. Seems to be more of a consistent pull than a drift with the road crown. When I let go of the steering wheel it wants to change lanes in about 3-4 car lengths. The wheel is centered, just needs a little force to keep it going straight all the time. When the road is crowed a little to the left it will go straight. Over the past year and a half I have done new wheel bearings (front + rear), trunnion bearings, and suspension bushings. It's also not a brake pull.
When I first lifted it I had the alignment checked and it was per the first image below. I had some death wobble so I machined new caster plates to reduce the caster slightly. The death wobble went away. I had it checked again more recently and see the reduced caster, but the camber was off. Not sure why the camber reduced, but this was also before I did new trunnion bearings + wheel bearings. There was a little play in the wheel bearing on that side, but just barely enough to feel with it jacked up. It it certainly didn't feel like enough to cause concern.
The 2nd shop that measured also recorded the rear axle. From that I see the thrust angle is off. Is that from lifting it using a stock track bar length? Could this cause my pull right?
From what I can tell my issue could be any of the following, but these are all non-adjustable correct?
Older Alignment Values
Most Recent ~1 year old at this point
- Camber up front would push it right (I should really get this re-measured with the new bearings as I don't see how it changed so much from the older alignment #s)
- The older alignment #s had 1/4deg more caster on the pass side which would help offset road crown? How would cross caster change on a solid axle?
- The thrust angle in the back is making it crab walk right?
