FZJ80 Loud Engine
California
Hi guys, hope all is well in these troubled times. I bought my 80 fairly cheap which in return has required me do all kinds on maintenance on it. I had my 80 sit around for the last 2 weeks and today, after turning her on I noticed a very loud hammering sound in the engine bay. The truck runs great and the sound lessens while driving or turning the steering wheel while idling.I have replaced all belts and pulleys. Could it possibly be my power steering pump? I've attached a link of my 80 while idling, look forward to your response and help.
I'm not sure what the sound could be, but you could undo the drive belts and see if the noise goes away. At least you could rule out the motor.
That sounds to me like power steering pump.
It started after sitting for a while? It wasn't doing it before?
These are supposed to have ATF in the PS system. There are a couple guys that run an actual hydraulic oil (I forget which version), but do NOT use the "power steering fluid" that you buy at the auto parts place.
You may want to consider removing your PS reservoir and cleaning it out. There is a screen in the bottom of it and it's possible that it is plugged and after starting and using the truck, it's dislodged some crud and clogged the screen, and its causing the pump to cavitate.
Awesome! Will be giving that a try. Thank you for the reply
