fzj80 inconsistent idle
odessa, tx
my 94 fzj80 will idle between 300 rpm and 1100 rpm at times. everytime it fluctuates up or down I hear a click under the dash like a relay or something. Seems to do it more with the AC on. Is this typical symptoms of a bad idle air valve or something else like a vacuum leak. I'm leaning towards replacing the idle air valve but before I do I figured some of you may have already been through something similar
high idle when the ac compressor is running might be normal? I forget.
A '94 has about 12 feet of vacuum lines in various diameters. Guess how i know. Many of them cannot be reasonably replaced without removing the throttle body.
With the original hardware still installed, it's really hard to remove the IAC valve without removing the throttle body - which is why i reinstalled mine with socket head cap screws before reinstalling the tb. Can't get to some of those screws with enough torque with a philips head, but i can finagle an L-shaped allen wrench just fine.
You don't need a new tb-to-intake-plenum gasket. At most you might need some hylomar or spray-a-gasket on the original (steel!) gasket.
Check the intake duct for cracks. Mine isn't cracked, but i did determine that i wasn't getting a good seal with the original clamps. Installing 3" t-bolt clamps on both ends helped a bit.
Since you live somewhere hot, I would not be surprised at all if some of your vacuum lines are cracked or loose. A bunch of mine were.
I think I will start with that advice and spend a weekend checking for vacuum leaks
