FZJ80 ECU swaps
Hello,
I've a customer with an A/T FZJ80. He got stuck on the sea and the water+12V rusted and damaged the ECU.
I've found a couple here in IH8M but are different part # although they've the same pins. Do you know if I can use one ECU with different part #?
For example, the ECU I've damaged is 89661-60271. Used lostit has one 89661-60652. Pins are the same.
Thanks,
David
From what I can see both part numbers are for a FZJ-80, but the second (89661-60652) is specifically referenced as a '97 ECU.
Here's what ToyoDIY has:
Code:
89661	COMPUTER, ENGINE CONTROL
89661‑60170	FZJ80
89661‑60220	FZJ80; CALIFORNIA SPEC
89661‑60221	FZJ80	$2,038.72
89661‑60260	FZJ80
89661‑60261	FZJ80
89661‑60262	FZJ80	$1,890.93
89661‑60650	FZJ80
89661‑60651	FZJ80
89661‑60652	FZJ80	$1,720.39
ToyoDYI simply lists all ECU's in that, from '93-'97. The ODB-I and ODB-II ECU's are probably different. There may be differences for US/Cali spec and the rest of the world. There are 9 ECU's listed there, hard to say what goes where.
What's the difference between the used one (89661-60652) and the damaged one (89661-60271) as far as the trucks go? Both US spec? Same years? Lexus vs Toyota?
I wouldn't assume that's true.
I would contact CruiserDan, he may be able to tell you the differences (or at least years) that the various ECU's are used on. That may help narrow it down.
If you used the same part number, obviously that'll match up. Failing that, I'd try and match same years. Failing that, I'd match same type (ODB-I vs ODB-II).
