Fzj80 cruise control ecu location
Perth Australia
Hi brains trust,
I'm currently trying to retrofit factory cruise control. I'm trying to find the location of where the cruise control module/ecu would be located. From my understanding it's in the driver's foot well somewhere (RHD Australian model). Does anyone have any pointers/pictures?
I know there's a bracket for the module, which I don't have, but can't find the wiring plug to save my life.
Thank you in advance!
Andy
On the RHD trucks the cruise ECU is mounted high behind the lower dash, near the steering column/pedal-box area—not down on the floor of the footwell. Remove the lower knee/side trim and look for the unused multi-pin connector taped back into the main harness; following the cruise wiring diagram is usually easier than hunting for a loose plug. Also verify the donor ECU and harness match the same market/year, and check the stop-light switch plus clutch switch if it’s a manual. We specialize in these trucks at 4x4 Rides in Hagerstown, MD and are happy to assist if you need us.
