FZJ80 '94 or '95?
San Diego
I'm new to the land of LandCruisers. Always wanted one and, now, have the funds to buy one.
Here in SoCal, I recently looked at a '94 and '95. With the assumption that everything is in good condition, my question is: Are the stock differences in the '95 worth the difference in price and additional mileage relative to the '94? OR is there even a significant stock difference between the two?
airbags and ABS brakes standard different grille(toyota sumbol) thats about it. The tranny is different in 95, not as stout accordign to some.
What AZ said.
You shouldn't have any problems with rust with a SoCal cruiser. Lots of mall cruisers running around this area.
What are your general whereabouts in SoCal. Big place you know.
BTW, IH8MUD welcome. :flipoff2:
You will find this welcome symbol to be a very friendly one. Read and search and you will find a wealth of info here.
Good luck with your search!!!
I'd pick the 1995, a little bias I must say - there have been posts that state the reasons why.
Glad you are buying a Cruiser though!!!
You are taking the right steps to a better life - also- there have been posts that state the many reasons why!!
Later-
D
Depends on what they have. If one has lockers and the other doesn't go with lockers. I regret not getting one with lockers. Also mileage, and condition. Need a wee bit more info
Whoa... didn't expect this many responses so quickly... thanks!
Are lockers options for both years? Lockers... meaning lockable diffs, correct?
When I said "new" I also meant new to off-roading also.
Located in not so Sunny San Diego.
Yes, Ron, lockable diffs. Frickin' awesome! THat's one of the things that seperates these trucks from the rest.
Yes lockeable diffs. The one with locking diffs is more valuable, and usually more expensive. Read up on the subtle differences between years.
Most dealerships/owners have no idea what lockable diffs are. Rigs with difflocks should be no more expensive than those without.
There are advantages/disadvantages to 93/94s vs 95-97s. None all that significant. Find one with disc brakes all around and lockers. Find one that's clean inside and out. Clean rigs are out there...you just have to be patient.
On the '94, a Jet Ski was towed around a couple times a week during the summer months. How much additional wear and tear can you equate this to in mileage?
I would say none. In my opinon it's not always about how hard the vehicle was worked, but how it was kept up. For example, if it's a '94 with let's say 50K miles (insanely low mileage) that means the wheel bearings and such have 50K miles on them. BUT, the brake system should be flushed no matter the mileage, just going by date, usually same with the coolant, etc. Some things are more mileage related than others. No matter what you get you're going to want to do some maint on it to make sure of it's condition.
As for '94 or '95. I'd say go with '95, but make sure you're happy with it, if they were identical then probably the '95, but if the '94 has a few things nicer, maybe been maintained a bit better, etc, then that would be a deciding factor. Also, don't sweat it to much if you get no maint history or anything. I got jack with mine from a dealership (non Toyota), they knew absolutely nothing about it, but mine only had 49K miles, so nothing really should have been done anyway. Buying a '94 or '95 now isn't quite the same, just expect that no fluids have ever been changed (hopefully oil, but I would doubt coolant or any gear oils), assume no knuckle work has ever been done, etc...not hard, just a few things to do to make sure your next 80K miles are trouble free.. :)
Oh and welcome...San Diego is nice, it's a shame the Chargers are so horrible! :D
On no... 1-15 (a few years back) is horrible. 4-3 is beyond great for us die-hard Charger fans.
What exactly is the "Knuckle"?
Lots of cruisers in SD.
If it's got lockers, it'll have disc all around - at least on the '94's - learned that from Cdan.
In the FAQ section, read the post on differentials for dummies. That should help alot. It did me.
Another thing to learn, we've got a great OEM parts source right on this board. Upper right ad for American Toyota, board member Cdan is the resident parts mgr. Ask for him or mention you are from this forum. Great info, great service and outstanding $$$.
Love SD - great city. Spent lots of time in Imperial Beach and theatre at the Old Globe. Traffice got to suck too bad, and dropped those tickets after over 25 years. Sad.
my '94's ac system has R-134a.....I think '94 is around the time they changed to that refridgerant which is i believe preferable/cheaper than previous refridgerants? I think some '94s have r-134a and some don't helpful? hope so...
Where's that "Diffs for Dummies" link?
Nevermind. Just found it.
That would be 93's with r12 and later r134.
BTW I like the r12 here in Texas better, everything else I'd rather have a 94 thou.
If you want to wheel it, get the `94 (I'm biased!). Beefier components. I had a cherry `97 with 70K miles, and my modded and beat up `94 with 140K miles, and I sold the `97...
If you want to drive the family around, get the `95 (airbags).
Of course, that's with all things being equal (mileage, locked, options, condition, maintenance records, etc.)
HTH,
dclee- what "beefier components" are you referring to on the '94? If you're talking about the "bus tranny", it seems it has been more prone to trouble with all the solenoid problems we've seen on this board. No such problems with the newer tranny. Also, in terms of sheer mileage, the highest mileage 80 we've seen (one with over 300k) had the newer tranny.
IMHO, all things being equal, go with the '95- it's a safer vehicle with the airbags (and no, they won't go off while you're wheeling unless you need them) and I believe it also has some structural improvements to the body (I'd search for robbie/Christo's post on this but I don't have time).
