FZJ80 1FZ-FE
Pakistan
I have a toyota land cruiser 1FZ-FE the problem with it is that when the engine is running and the oil cap is removed the engine starts missing and rubbling very bad and sometime dies. Can anybody tell me what is wrong with my car
runs weird with oil cap removed?
its a huge vacuum leak. they are not supposed to run correctly with unmetered air going through it.
nothing is wrong with your engine. dont take the cap off while running.
problem solved
Check your pcv valve and that the correct hoses are connected to the pcv and breather
problem solved
^ this. While you are at it, don't drive without your gas cap on and lug nuts tight :flipoff2:
its not about running with the oil cap removed the truck when cold misses badly when accelerator is pressed harshly but when i take the revs up gently it goes up without a hick so i was wondering if the oil cap issue is linked somehow please help.
That is perfectly normal. You create a huge vacuum leak when you remove the cap. You are lucky it runs at all when the cap is removed. Not sure if I understand why you are concerned. Don't run the vehicle without the oil cap ON.
its not about running with the oil cap removed, the truck when cold misses badly when accelerator is pushed harshly but when i take the revs up gently it goes up without a hick so i was wondering if the oil cap issue is linked somehow please help.
s
Look,
If now you're saying it also runs poorly even with the cap in place, you might as well start over with a new thread and focus on those symptoms.
so mate is it okay to have the rpm dance when the cap is off!
The rubber intake hose from the aircleaner is ripped? When you stomp on the gas the torque leans the engine opening the tear. Gently revving it doesnt cause the lean and opening of the hose?
Just a guess. Mine was ripped and it was hidden, but periodically showed up
This thread got all mixed up with delayed answers and such, let me restart by saying - No the stumbling with the cap off is probably not related to your other problem. First check the intake hose for small cracks as Booger weldz said, and then get back to us - but stop mentioning the oil cap, it just makes everyone crazy (including me).
OK,....my brain just got scrambled by reading through all of this. OP, since you now have a new thread, delete this one to prevent further injuries.
:slap:
