security electrical problem: for no apparent reason security system alert initiates and sometimes car will not start. Key fob turns off alert
The alarm system was factory installed and permeates everything. I don't know how to pull it out. So far I've just pulled the horn module to keep the noise down. Sometimes you'll see the security light flashing and I have to use key fob to stop it; other times it just does nothing when you turn the key and if you wait 10 mins or so it will then start.Pull all that crap out. Problem solved.
No alarm is going to prevent a thief from stealing your truck. You need a 24/7 armed guard or a very large dog.
There are no "factory" installed alarms available on 80s. They were all port or dealer installed, and some of them pretty poorly. They are not all that invasive to the factory wiring, and not very difficult to remove. Just do a quick search for "RS3000 removal" and you'll get lots of info on the subject.The alarm system was factory installed and permeates everything. I don't know how to pull it out. So far I've just pulled the horn module to keep the noise down. Sometimes you'll see the security light flashing and I have to use key fob to stop it; other times it just does nothing when you turn the key and if you wait 10 mins or so it will then start.
