FZJ70 Steering Box
DSP
USA
Does anyone know if the steering box for the 1993 FZJ70 (Part # 4411060370) would be interchangeable with the steering box for the FZJ80L (Part # 4411060212). They look exactly the same in the pictures online (Partsouq and eBay.
Thank you for your help.
Hello,
The 80 Series steering box and its pitman arm are specific to that drivetrain. Keep in mind that 80 Series axles are wider than their 70 Series counterparts.
70 Series steering box and pitman arm are model specific as well.
If you choose to use the 80 Series box, you may have to source the pitman arm as well.
Some fabrication may be necessary, and the setup may not work as expected.
It is better to use the proper part.
My two cents.
Juan
Hello,
You may have to source the pitman arm as well.
It is better to use the proper part. Otherwise, fabrication is needed, and the setup may not work as expected.
My two cents.
Juan
Can you use a 80 steering box and the pitman arm from your rig?
