fz teardown pics
Calgary
So The middle eastern - Arabs rev them to 8000 eh :grinpimp: but 2nd and 3rd pics, so nice and clean what did they use? of course not the 3M scotchbrite pads right :hillbilly: these summer I've gotta to make my 1FZ look the same as those ...below ;)
I use a toothbrush after sticking it in a wash tub filled with degreaser for a while. Works great.
Look back, I posted about SCE gaskets. You can buy multiple thickness SCE copper headgasket for the 1fz-fe.
From reading his back posts on toymods forum, he was running 19 psi with a GT42 turbo before he had any issues with the headgasket and headbolts... At about 23 psi he was running into valve float. Finally he killed the engine at I think about 23 psi and a 100 hp shot of NO2.
I think it is safe to say that the 1fz bottom end is bullet proof.
Another note He stated that the stock FPR can be shimmed to 55 psi. Think about it...
He also psted that the cams are his limiting factor for making the engine a dyno queen. I agree the cams are set for torque and low HP... I have been wondering if a cam regrind would really help the 1fz out on the highway.
Another note from his back post is that a LC ennginering 3rz adjustable cam gear would fit the 1fz-fe. You can shave the head and get back to stock timing "if" it fits.
:beer:
The heads in those pics have the receiver grooves cut in them to "lock" the gaskets into place. Nice engine building trick.
The problem with copper gaskets is that over time they start to weep water. Had this problem with BuickGN (3.8i turbo) motors. Copper head gaskets are pretty much used for extreme duty race builds.
Those are some crazy numbers for a stock motor. I know that Toyota overbuilds their engines..... gotta love to read stuff like this. 81lb crankshaft!!!!! Holy moly!
Video: http://www.youtube.com/watch?v=6QS7MrBYrqE sounds just like a Supra :)
Nice find gnx7. That is a work of art.
He noted on the other forum the stock gasket and headbolts held to 19 psi... See no reason around here for the copper gasket any time soon. I am really interested in the SCE titan gasket at triple thickness then head studs, and finally correcting the timing using the adjustable cam gear.
Anyone want to buy my pickup????.....
Any reason for triple thick?
Interesting that he notes the bearings were in such good shape he chose not to replace them with his rebuild.
I saw that too. Plus, he was too "lazy" to clean up i think the intake....something. if i were tearing into something like that i would touch everything! :o
As I recall, that comment was made before he sent a piston through the block. Maybe he should have replaced the bearings? Nevertheless, it is facinating that despite all the abuse the engine endured prior to the rebuild, the bearing still looked good.
The busted rod was due to monster cylinder pressure causing it to buckle and take out the wall of the cylinder, then the counterweights smashed the bottom of the piston up and snapped the rod completely as it was straightened back up.
I just pulled the piston last weekend to have a look.
Bearings were not to blame-just 26psi boost and nitrous (surprise surprise:) )
Messy. Very messy.
With some forge internals it should be very fun.
At least it's shown where the limit is on std internals.
Sean:)
