FYI bushing info
San Antonio TX
For those of us who are contemplating or in the midst of the mini disc conversion and will be needing the bushing for the tie rod. The Borg Warner Part # is SB0, and that cross references to Auto Zone # 4200B. I'm posting this because I've been searching for a little over a week and NAPA, Oreilly's or any of the other local stores have no clue what I was looking for. Hope this helps someone.....
Kevin
Also, If your tool poor like me and don't have a vice to press the bushing in. You can use a bolt that will fit thru the steering arm, put washers on either end and tighten it up. It will seat it just right...
Josie'sLandCruiser
Stop calling it a "FJ."
Seattle, USA
Thanks for sharing!
-Alan
Monroe, WA
Thanks for sharing!
-Alan
X2.
I wish I had known about this bushing when I did my mintruck swap. I had a machinist friend cut the ends off the original steering arms, mill them down to ~3/4" and cut threads into the outside. Them he milled out the minitruck arms and tapped them (not all the way through). Once the inserts were installed, he peened them. I'm not worried about them going anywhere... :D
That is a great trick for seating bushings, I'll have to remember that one for the future.
