Fusible link question - Which wires do what?
Cincinnati, OH
***THE FUSIBLE LINK WAS THE CULPRIT. HAD THE TRUCK TOWED BACK HOME.
REPLACED THE LINK AND THE TRUCK SEEMS TO BE FINE.
THANKS FOR ALL THE HELP!****
Driving truck after some very mild off road. Get back on main road. Truck looses all power and stalls. I'm on the side of the road. Truck will crank fine but won't start. Right before it died it was sputtering like it was out of gas or couldn't get gas. Help. Ideas?
Check your battery terminals, specially ground
Replaced the fuseable link about 4,000 miles ago. Don't have a spare on me.
Is there a work around for the efi fuse to get me going?
The one in the fourth position from the front of the vehicle is a spare. If you have one in the second row, you can also use that.
No spare in the box.
Are there any other round metal fuses on the truck that I could use to see if the efi fuse is the problem?
Yes. Like I said, there should be several next to the left foot under the footpanel.
They are all the same M4 fues.
And while you're at it, spend $3-8 and pick up several spares on ebay.
I just swapped the efi fuse that's not the issue. Thanks though!
Must be the fuseable link, no spare here. Going to see about having the truck towed.
You can temp hardwire the link to get going, but don't leave in place. Did you read the link I posted to FAQ on troubleshooting steps?
Probably not the issue, but I got dust on the MAF? once after following guys out after a day on the trails for 10kms. Would run but no power. Disconnecting battery to reset the ECU did the trick.
I had the truck towed home and replaced the fusible link that I forgot to take on the trip. Really kicking myself for forgetting to take the parts bag on the weekend trip.
So now my question is:
What is usually a good place to start looking if the fusible link does blow?
Or what are some common causes for the fusible link to blow?
I replaced the link and the truck runs completely normal now.
That's a good question. OP says he replaced the fusible link 4000 miles ago, so unless it was a used part the failure isn't due to age. Something had to burn it up.
Yep, I need to figure out what caused the fusible link to fail.
Looks like it was the pink wire from the fusible link that fried. Have to start searching to see what causes that.
I would start with what you know: You know what wasn't working. I think the troubleshooting guide referenced earlier groups accessories together. I would guess you'll find the overload on one of those circuits. Too simple? It might be, but it seems like a place to start.
same thing happened to me in a period of 4 months - lost two fusible links. 1st was presumed to be the original. the 2 nd was a new one from toyota. in both cases, it was the pink wire with the grey connector. i believe this sends power to the ecu because in both instances, the check engine light did not come on. both instances occurred at the worst possible time - while wheeling and climbing steep inclines. i'm very interested in hearing what others have to say because i'd like to know the root cause for the ecu to pull enough current to blow the link.
I believe that is the "AM 2" fusible link (FL AM2) for the ignition circuit.
Diagrams:
