Fusible Link, no start advice
Hi all, great forum
I have done a lot of reading and searching and with your help I was able to find faulty FL. A little history: 1995 LC with 275,000. Been with us since 1998 and now driven by my 19 year old daughter (got to love teenage girls). Was running fine then stalled and won't start. Turns over but no spark. Findings so far:
No spark
No CEL
new EFI relay (still no CEL)
burned out Fusible Link - FL-AM2 white wire to gray connector
disconnected AFM - still no CEL
good power to fuse box
12v to EFI relay #2, no 12v to #3 with key on
multimeter shows continuity from ground to 1,3,4 on EFI relay plug (does this indicate short?)
I am going to stealership now to pick up 2 Fusible Links. My questions: Is it likely that my issue is just the FL? I would think something caused it to fail other than just old age. FL-AM2 goes to Ignition Switch, Ignitor, Coil , and Injectors - what would be the most likely culprit? What I am trying to avoid is replacing the FL just to have it burn out - my first thought is to remove the fuse box and inspect all wiring looking for any shorts but I would love some input from the smart folks on this forum. Thanks in advance - again, great forum.
Mike
Just use a jumper instead of the FL and see if it starts. If it does, replace with the FL and go from there. Really not much else you can do. Did the FL burn or did it break it half?
Before installing the new fusible link, disconnect battery and then measure (ohms) resistance between the harness side of the fusible link connector and body/chassis to see if there is a short.
cheers,
george.
LFD - i tried that and jumping is apparently not recommended - the jumper wire started smoking so I stopped
George - will do.
Just installed new FL and turned key to on for a sec and now do have CEL but even in that short of a time (less than 1 second) wire was warm.
Sounds like a short, might want to check the harness next to the egr tubes under the intake things get real hot and brittle under there. I know some guys including myself wrap that area with heat tape
so far:
disconnected FL - no continuity from harness side of FL-AM2 to ground (so no short, right?)
removed 7.5 amp ignition fuse at inside fusebox and jumped FL AM2 with low amp fuse - which would blow with key in on position. This makes me believe less likely a short and possible coil or igniter bad
I have to stop for the day - thanks again, will report back when I have more info
Revisiting thread - I have all day to hopefully get her done.
Tested Ignition coil resistance and think I found my problem. Primary coil showing 0.0 and secondary showing 6.36 (1/2 of spec). Looks like a short in the coil.
My thoughts: short in coil caused FL-AM2 to burn out which in turn leads to no CEL and no start - does this make sense? I would like to find the problem before I start buying and throwing parts at it.
Thanks, Mike
Problem solved - I hope
rechecked resistance on coil and looked OK. tried to start with 10A jumper in place of FL and started without problem so:
either just old worn out FL or I have a intermittent problem. Guess we will find out
