Fusible link help
Memphis, TN
Replacing the batter cables today, while I’m at it I’m replacing my fusible link. Noticed during the cable removal my link doesn’t have the plug connector. All 3 links were in the fusible link box. I ordered these 2 parts 82998-12470 & 90980-10982. Just want to verify that the white & red wire is what I will solder the new wire to. The second picture is the original condition I found, the first is after I removed the red extension wire
Replacing the batter cables today, while I’m at it I’m replacing my fusible link. Noticed during the cable removal my link doesn’t have the plug connector. All 3 links were in the fusible link box. I ordered these 2 parts 82998-12470 & 90980-10982. Just want to verify that the white & red wire is what I will solder the new wire to. The second picture is the original condition I found, the first is after I removed the red extension wire View attachment 2477150View attachment 2477152
I don't have the '96 EWD handy, but...
(from the '95 EWD)
(from the '97 EWD)
I think it's a safe bet that the '96 circuit is the same.
Should be the white/red. Here's a photo if you need a visual reference, I just did a big wire harness overhaul myself. There should be an electrical manual PDF floating around here some where.
I personally don't recommend solder connections in the engine bay. Mechanical connections are preferable. I use "heat shrink butt connectors" with the correct crimp dies/tool on all auto and marine applications. But I know people that use solder butt connections so its up to you in the end.
