fuseable link
It didn't come from the factory with one. There are simple ways to build/add them which you should be able to find with search.
You'd better consider redoing your harness if you are going for 100 a.
Thanks
I went out and bought a Haynes manual this afternoon..
you are Right there is none
gonna have to install one .
Factory harness will stay as it is. as I have no intention of loading
it up.
My old alt died. so I am putting a 100a alt in it for winch and stereo
etc.
Which are High amperage draw taken from battery directly..
at least thats the way I run em..
Now, I am off to order a FSM
Good plan! :beer:
you should do a search on the suject, you may have to eliminate your amp meter or add shunts and i know some people dont agree completly with this guy (sorry pin head) but its a good read
www.madelectrical.com
forgot to add look in the electrical tech section of the site.
Just my .02
Not trying to start something just food for thought:
wires are sized for the load placed on them.
Fuses are sized to protect said wire.
regardless of where a load is on the vehicle, the altenator is going to be supplying the current to operate it. So if you have a stock harness and a single battery system, the high draw devices will eventually cause problems. Probably not right away. Perhaps not until you "have to use' the winch and/or lights with a low battery charge.
IMHO: In your configuration (as descibed): upgrade (from stock) the cable size between the altenator and the battery pos. terminal; ensure that each high draw device has wiring and individual fusing of appropriate size; If said devices are switched via any portionof the stock harness a relay should be employed to isolate the high amp load(s) from the rest of the system (similar to a head light relay or a starter solenoid); Individually ground each high amperage device to the frame. Shy away from grounding to things like windshield frames and other body work.
Again just my .02.
I got it covered.
My winch and stereo amps are grounded back to the battery
Thanks for the input.
I am a millwright heavy on the electrical background.
I just wanted to know if there was a fuseable link
If not I need to protect the old harness with a fuse.
Thanks lonegunman.. the PO already disconnected the amp guage
and installed a Volt meter.
Good lookin out!!
