Fuseable Link new to site.
Grave..
Welcome to the site. U need to mention what year 80 series; miles (kms) and anything else that would help us trouble shoot the system.
The black fuse link (AM1) in a stock FZJ80 feeds 4 primary fuses; the AM1 50amp; Haz-Horn 15amp; Dome 10amp; and ABS 60amp. EWD189U, page 36.
When u hit the start side of the ignition switch, current flows thru the 50amp AM1 fuse [Relay Block #2, under hood (bonnet)] to the P1 Park/Neutral switch to the starter motor. This operates the starter solenoid, cranking (turning over) the engine.
Assuming that everything is alright with the ign switch in the "ON" position; I am going to guess there is a short in the line to the starter motor. One would think the 50amp AM1 fuse would blow, but from ur description the 50amp AM1 fuse does not. This 50amp AM1 fuse feeds a lot of other circuits, so u need to isolate the problem.
Remove the B-R ( Black-Red ) lead to the starter motor. Check to be sure that u do not have any other fuses that are blown. Replace fuse link with a new Toyota one, or a piece of wire same size and length. With the lead to the starter removed, rotate the starter switch to "start" position. Does the fuse link blow or get hot?
U will need the EWD189U (for 1994) for further trouble shooting.
As mentioned, the problem could be the starter motor assembly (solenoid) or the wiring feeding same.
Ref: EWD189U for 1994 gas (petrol) Wiring Diagram. 1FZJ-80 engine.
Ref: RM360U Repair Manual.
Ref: http://homepage.mac.com/dfmorse/BattProj2/page9.html
Ref: http://homepage.mac.com/dfmorse/FuseChart3.5.1/
Thanks dfmorse. My rig is a 93 standard diesel, HZJ 80. It has a 1HZ motor and has done 320000 Ks. Not sure about miles. [Id have to do some sums.] It has a 4" lift , Homemade custom drawers in rear, dual batterys. I am in the process of fitting a PTO winch, which was originally on a FJ 40. Needs a bit of engineering but is all going well.I have a very bad habbit of getting stuck nearly everywhere i go. Hopefully this will stop that.
Anyway back to the problem, I have rebuilt the starter so thats fine, and i will do the checks that you have suggested .Im not familiar with these forums and im bumbling my way along, so please bare with me if i seem a little clumsy.
The fuse link only blows when the ignition is held in the start position for too long. It is fine if it starts straight away and the switch is returned to the run position, although the link gets hot. The 50 Amp fuse has never blown.
