Fuse Block Terminal
Utah
Does anyone have a part number for, or where to source the fuse block blade terminal? I found the part number for the repair terminal with a piece of wire already crimped to it(82998−12140) in the wire harness repair manual, but I just want the uncrimped terminal.
Take a look through here might be hiding.
If you know the size ballenger motorsports sells everything connector and wiring related.
I am building a new harness, so much prefer not to have any unnecessary splices. I did find a terminal on aliexpress that looks correct and have that ordered, but who knows on the quality, I guess we will see. For now I will just leave a service loop and splice in the pigtail so I can cut it off and crimp the terminal if they look good.
I am building a new harness, so much prefer not to have an unnecessary splices. I did find a terminal on aliexpress that looks correct and have that ordered, but who knows on the quality, I guess we will see. For now I will just leave a service loop and splice in the pigtail so I can cut it off and crimp the terminal if they look good.
this is the answer. I ordered from them as well to build a harness for my truck using the correct terminals. Easy to work with, just think through what you need.
I get all my connectors from Ballenger
