"Fury" THE BUILD
Finally got all the parts needed to fix the PO handy work / fire hazard
A 5.3
Super Cool.
What state are you going to register it in?
I took out the msd that the PO put in and re wired the factory ignition system back in and the 3fe is running strong again just past 250,000 and climbed the grapevine 3rd gear 55mph on 37
When I got home from the beach trip noticed some fluid on the rim at first I thought it was break fluid but it was grease from the hub there was also a good bit on the knuckles. I was worried because I just had all the seals replaced and new bearings but thanks to the help of mud I checked the breather house and it was packed solid so I am cleaning everything up and will check on the next road trip
Upgraded the front brakes to that later year model with 100 seires pads and repacked the birfs
Clearanced the front fenders no more rubbing I will weld the holes up next time the tire is off
