Funky ABS / Brake issue after new SS lines installed.
КАГІҒОЯИІА
So, some of you may have read this thread about how I tore a metal brake line off during some heavy wheeling when my sway bar broke off. Same thing happened to Alvaro.
Well, I got the replacement part from CDan and, while replacing that, decided to put all of my new SS brake lines on.
Although that job is a pain in the ass to level 10, there were no major issues getting things done.
I kept things as clean as possible and when finished, followed procedure on bleeding the MC and then all of the lines, PS rear first, then DS rear, LSPV, PS front and then DS front. All went perfectly. Brand new fresh synthtetic fluid all the way around.
So I get in for a test drive, and the brakes felt alright, still nothing to write home about but that is the curse of the 80. Anyway, I noticed that the ABS light was on and remembered that I had pulled the ABS fuse while up on the trail as I was limping out on three brakes and did not want any wacky pulsation.
After I put the fuse back in I went for another test drive, and when I jam on the brakes, I get this funky GIVE in the pedal and feel the ABS actuate but it really pulls hard to the right, which is the brake I tore the line on. :confused:
The ABS light comes on, then goes off. I try it again and the same thing happens, but only when I really stand on it. Then the ABS light stays on. I shut the car off and then disconnect the battery, hoping that perhaps it just needs a reset. After five minutes, I hook the battery back up and give it another shot, still doing it. But now, the ABS light comes on and then shuts off after a second.
Anyone know what I could possibly have done now? Maybe I got crap in the ABS unit? I heard those were rather sensitive.
Any advise folks?
I'm betting the ABS line is no longer intact on the side where you tore the hardline. It only takes a bit of a pull to internally pull the wire apart. Having one of the ABS wires not working will give you the constant ABS light on the dash and also give you the other issue of the brake not functioning to ABS behavior
And replacing that line? Cost / :banana:?
I have no idea if this is applicable but after my hg which took over a week so the battery was disconnected I had weird ABS pulsing & pull to the left a few times.
This "healed" it's self. I had the system checked immediately and it got a clean bill of health fwiw.
the front harness is all one piece. you can test it on the truck for continuity first to rule out if that is indeed the problem. it is pretty expensive from toyota IIRC but should be able to be sourced from a junked one.
I have torn my front line 2x. 1st one I bought from Dan--it was expensive.
2nd. time I took the harness off the car--cut into the coaxial like tube--inside there are two normal wires--just sodered them back together. Still working great.
same exact thing happened to me after having my wheel bearings replaced - abs sensors were all gunked up - replaced them and the problem was solved
Follow Up!
So, I took the advise of the guys here and went right to the ABS sensor on the PS, where the original trauma occured.
I cleaned all around it and pulled it out, cleaned the grease off of it and the little nipple on the end of the sensor. There appeared to be some slight etching on the very end of the nipple, much like you would see on a used distributor rotor. I then put back together and gave it a test drive. Still acting up in the exact same manner.
Pissed off now, I decided to give the same treatment to the DS, even though there was no trauma there. When I pulled that sensor out, the nipple on the end was three times as bad with etching as the other side, to the point where there were rough edges. I pulled out a small file and smoothed it out as best as possible and cleand all the shavings off. Put it back together and gave it a test run...
Works great...:confused:
I am happy and all but what the hell? Why would that cause all of that havoc?
When I get back from Tahoe this weekend I think I will do both of the rear ones just for s***s and giggles.
Anyway, thanks for the info fellers. Hope this thread helps someone else in the future.
:beer:
