Full Thread Replace Stepped Thread Brake Fittings
North Front Range, CO
I need to run new brake line from master cylinder.
I got new brake lines from Napa and they are not stepped thread they are full threaded. Left stepped, right full threaded. Do I need to remove the fully threaded fitting and install the stepped thread OR will the all threaded one work in the master cylinder. I assume I need to use the stepped threaded one but had to ask. Don't want to cut a new line if I don't have to.
http://www.napaonline.com/Catalog/C...eel-Hydraulic-3-16-/_/R-BK_8131271_0361183180
Note the pic shows a stepped tread fitting but its a full thread.
brakefitting-jpg.363450
The seal is made by the flared end of the pipe being pressed against the inside dome. If possible, take a look at where you are mounting the brake line. If it has threads almost all the way to the bottom, go ahead and use the NAPA lines. If not, I would cut and reuse the stepped threaded fitting.
My second thought it to just screw the new line in. With that much difference in the step, the brake line should have a bit of in/out movement
I believe the point of the step is two-fold:
1) As you tighten against the tapered fitting, the end of the nut will stretch out and bind in the hole. The step with no threads prevents the binding.
2) Threading the holes for the tube nuts to fit into is a lot easier and doesn't require special tooling with a stepped tube-nut.
Screw the new line in and get the fitting snug as you normally would. Then see if there is any play in the line. I'm not sure if Toyota's female threads are deep enough into the hole to allow for a non-step tube nut. If you are in a pinch, go back to napa or another store and get some different nuts. If you can wait, order proper tube nuts online.
I'm not sure if you can order JUST a tube nut from the dealer, but you can certainly buy a cheaper, short section of brake tube which already has flares and nuts. Probably something from a mid-late 90's Camry will be cheapest.
Could easily remove the threads on a grinder-holding by the line and turning it or letting it turn itself and using your finger against the back side to brake the nut to not spin out of control.
