full floating rear and locker
arkansas
I am buying a full third member with 4.88 gears (front and back) that is set up with an arb in the front and a powertrax in the rear. I am putting this into a full floating rear and have heard some people have concerns about automatic lockers and FFs. So my question is should I
1. just put it in and not worry too much about it or
2. put the arb in the rear and the powertrax in the front (not sure if this will do anything to correct the problem since the front is also a ff) or
3. remove the powertrax and sell, put arb in rear (is this difficult)
Do they not run an automatic lockers in australia?? I know that 99% of there axles are ff and I am sure they run auto lockers.
THey do run autos in Oz. ;)
Some people have reported problems with their FF which they attribute to their autolockers. Shearing axle dowels and hub studs.
Not everyone with FFs and autos has had this problem. I am not personally convinced that there is a link between the failures and the autolockers. Too small a sample and there are others running the same setups who have never had a problem.
Mine is working fine but while it has seen a lot of use in the time I have had it set up this way it still hasn't been all that long.
Mark...
I am one of those who has not had any problems what so ever with an auto locker and a full floater, not even a loose nut after a few days wheeling or 1800 miles down the road. Some grease on the cone washers+ red locktite on the nuts: no problem.
Selectable lockers kick ass, but otherwise an auto locker is a fine compromise.
Mark...
Some of us are snapping those even running open back there. Upgrade your studs. I'm dropping an aussie in the 45 which has a FF hopefully this weekend or next.
Mark...
problems with snapping hub studs = old studs, not tightening them religeously till the cone washer is seated (if i pull my diff, i'll torque em to spec before every time i drive it TILL the torque hasn't altered after 3 weeks of driving.
also if you reuse them, the corrosion eats through them and weakens them... also tightening em down and loosening em off a few times really stretches and weakens them
and if you still have problems, redrill them and tap em to take 10mm studs.
1 year abuse with a detroit in my FF rear, and i've busted CV's, driveshaft tubes, and transfer cases, yet not had a rear axle prob.
oh and don't lock tight em... because the "loosening" isn't usually the nut backing off the thread, it's usually the cone washer seating (i.e. if you beat the axle flange to get em out, they gotta force it back to round).
