Full Floating Axle Questions
Fort Collins, CO
Okay, I had two leaks to take care of on the rear axle of my 1978 FJ45. First, I had an axle seal leak and second a rear diff leak.
I've done a search on either using RTV or cork gasket on the rear diff and it seems there is some preference towards the cork gasket.
How about on the axle seals? Since I have to remove both axles to get the rear diff out, I'm at the point where I either need to pick up some axle gaskets or use RTV. Any suggestions on which would make my job easier and last in the long run?
Do I reuse the cone washers or do I need to replace them? Are they one use items?
It appears that there are two stud posts that help to line the axle up with the hub. On one of my axles, there is a post missing. Is this a concern? Is there a replacement part I can order? Is this missing post the cause of my original leak on that axle?
Thanks in advance.
Michael
Gaskets every time.
RTV works great to get you home.
You can re-use the cone washers, and will want to replace the dowel that is missing.
Fix it right the first time.
Good luck!
-Steve
Thank you sir. I will do that. I will get my list together for CDan, since i mutilated a cone washer or two.
You must have the dowel pin in place. Dont ask me how I know. You should also replace all the threaded studs in there. They stretch and weaken over time. Toyota has all the parts and they are cheap.
it is worth while to add 2 extra pins. Do a search on POR under my name, dd113, and yo can see how I do it.
Dd113, I did a quick search with POR and looked for you as the thread starter, didn't see anything but I only read through really fast. I'll try again here.
I have another issue while I'm working with the rear axle.
I have the rear diff out and both axle shafts out. On the driver side, the drum brake cover comes right off, is this normal, or should there be a screw or two holding it on?
Also, on the passenger side, the drum is on there very very very tight. I notice that is I spin the drum, there appears to be a sticky spot, where the drum spins freeley until, lets say, it hits 7 o'clock. Normal, or do I have an axle bearing that needs replacing?
DD113, one last thing. You suggest replacing all of the axle studs. Is there any tell-tale sign that they are due for replacement? Maybe the wiggle in their hole a tad?
Not David but here ya go...
You have a brake shoe dragging on the passenger side.
The studs...
They are used, and not expensive to install new ones....SO....change them, so you know that they are all new, and do the upgrade that David wrote about on Pirate...
Good luck!
-Steve
Poser - dragging brake, thanks.
Any explanation as to why the driverside drum practically falls off, while the passengerside is REALLY on there?
Okay, and I think I found DD113's post on POR.
So I should get all new studs, cone washers, washers, and nuts from Uncle Toyota along with one replacement dowel (for the one I'm missing) and four additional dowels (two on each side). Then tap the two additional dowels into the hub.
How are the dowel pins held in? Any tips on getting the old studs out? They seemed to be in there pretty damn tight when I checked this morning.
