Full compression On L shocks
Tulsa, OK
A while back someone was commenting on L shocks in the front, and that you'd never get enough articulation to bottom them out anyway, so bumpstops aren't required. Was out playing a bit this Saturday, and I decided to look and see how close I was to hitting my 2" lowered bumpstops. The pictures are pretty self explanitory.
Looks like your touching the stops, but not anywhere close to using all of the shock travel?:confused:
Well, 2" bumpstops do waste .75" of uptravel on L shocks in the front. Or is is 1.25" in the front and .75" in the back, I forget. But that's what Slee and MAF supply with L shocks, is 2" bumpstops. FOR might be closer to maxing out the shock at the same time as the bumpstop, since they're not constrained to the L shocks.
I'm sure I could get it to compress the bumpstop if I went down that same hill and rut and got all the weight transfer to the front. Or went fast enough to bump it a little. Or had a winch and bumper up there.
Other than the thread on bumpstops not hitting where they're supposed to, haven't seen any pics of what it looks like at or near ful compression. I thought it was interesting.
You're a little more than 1.25" away from bottoming out the shocks, of course you'll touch the bottom of the bumpstop, but you wont bottom out the shock.
SO? I guess that just means that 2" bumpstops are less than ideal for L shocks? Or, conversly, since you have to have about 2" bumpstops to run 315's or 35's, L shocks are less than ideal for running 3" lift and 35's?
If I had any weight up front at all, I'm sure I could bottom that shock out. The limit of front articulation just means that when I get the one side to bottom out, the other side is going to be far from fully extended, which is not a problem on the 4 link rear.
How much of the shock body is exposed under the dust cover when an L shock is fully compressed?
To quote Slee's site, quoting ARB:
To quote from the ARB fitment guide
"OME850J/OME863J coils and N73L/N74L shocks should be installed together, although they do not comprise a kit. Fitment of N73L/N74L shocks requires mandatory installation of .75" (20mm) Front and 1.25" (30mm) rear bump stop spacers to the front and rear suspension to prevent shock absorbers from bottoming out under full compression. These bump stop spacers are not available from OME and will need to be sourced from the installer."
So, it should be about 1.25" wasted up travel. In my photos the bumpstops aren't compressed at all, so that would probably be another .5" or so. Would another 1.75" movement bottom out the shock? Don't know, I'd have to know "How much of the shock body is exposed under the dust cover when an L shock is fully compressed?" in order to know that.
It's just a picture of the suspension compressed to the bumpstop. Hadn't seen one on this forum, though I'm sure there is one somewhere. Take it for what it's worth, and make your own conclusions. I'm sure anyone else running 2" bumpstop drops with L's would see the same thing. Perhaps minor differences depending on what caster correction your running.
2" bumpstop drops with L's is what comes with:
Slee's 4" kit
Slee's 6" kit
MAF's 3", 4", 5" competition coil spring kits they're 'normal' 3" kit with J's doesn't include them, but since it has L's I'm sure they're needed.
I haven't seen anywhere where anything but a 2" drop is used with L shocks.
The easiest way to tell is measure the shock with the suspension compressed, the fully collapsed length is ~15.25".
Measured where to where? Bottom of bushings, top of bushings, mid bushing? Much easier when it's eye to eye.
OME suggests the L shock because without it you wouldn't have any droop. A 12" travel shock of another brand (Pro-Comp for budget, Bilstein for high performance) and adapters, along with the 2" bumpstops for running 35/315s and your suspension travel is optimized (the FOR route).
I hate shocks with metal boots. You can't see what is going on. You are correct that the FOR shocks (Bilstein) have about .5" of travel remaining at rear bumpstop contact, which allows for some bumpstop compression.
I haven't done the front as I don't run offroad at high speed. Even if I do manage full compression it will be so constrained at that point it's not going to hurt the shocks. I have the front drops and will probably install them one day, but it's of very little concern to me as I ran Bilsteins for years on an unrestricted front end using the shock as a bumpstop with no ill effects, and that was not light duty stuff.
Keep in mind that L shocks are 11" travel, though, while FOR is 10". So you are netting out about the same travel with a 2" bumpstop drop. It isn't so much about wasted travel as net travel and balance between up and down (and whether you like the ride).
You're just gonna have to do the FOR kit when it finally hits market to get that premium ride. Tractor in a tux on an LX :grinpimp:
IIRC OME's are measured from the base of the pin mount.
Hmmmm.
Interesting that you dont have the chassis mounted bump-stops, that some 80s and 105s do. Both front chassis bumpstops are different BTW.
When fully compressed, front Ls measure 2 5/8" or 65mm from the stone shield to the washer on top of the bush on the axle housing, If that helps.
When I fitted mine, I fully compressed the shock and drew a line at the end of the stone shield, showing me how much compression I had availible. Then I made spacers under the chassis bump stops to suit.
I wasnt really fussy, and just used what I had, so I would have lost a little travel.
My fronts are spaced 12mm, but the rears are much more, to suit 36s that are not on any more, so no accurate measurement - sorry. But my 105 is spaced 25mm at the rear.
That might not be the best way, but thats how it is!;)
Hope this helps.
Matt
Matt,
I have chasis (frame) mounted bump stops on 35" tires.
From your experience. What would be the bump stop extension required for this setup?
I've not had any issues with my shocks so far.
Regards
Alvaro
So how close was your 35" tires to rubbing?? Do you think if you used all the shocks, the tires would still have enough room?
my rears rub a little on the inside cause I only have 1.375" of bumpstop spacer.
The fronts could probably be 1" less spacer and still fit my 315's, which are a little shy of 35". I think I could leave them where they are and run 36".
