fuel/water separator 1HDT
The racor one has its own thermostat built into its electronics. Turns on and off by its self. From a quality stand point , I would not worry... racor builds far more of the OEM setups than you could imagine. there are 2 different water in fuel probs for the setup I used. One has the detection electronics built into the sensor , the other does not and requires a goofy external alarm box to be installed under your dash. I no longer own the truck but Nolan on this site does. The water in fuel probe with the electronics built in outputs a ground signal . There are 3 wires, one is switched power, one ground and one output. I can’t remember if the light on the dash needs power or ground , but if it needs power a simple relay would solve the grounded output problem.
