So ive been having a problem with the 78 40 as of late. here is some background....first off i am a novice mechanic and am learning as i go so detailed responses would be awesome...heres the problem...i was cruising along and noticed a drastic loss of power during acceleration...the problem gradually got worse until i could not even get it to idle with out the choke on...i cranked up the idle adjust until i could get it to run without the choke on but put it in gear and roll a couple feet and it dies as soon as you stop...i have changed the fuel filter, blown air through the line from the filter to the tank and from the fuel pump to the carb with out much restriction. if i blow(and this is all just me connecting clean fuel line to the existing line and blowing through my mouth) from the filter to the pump I notice some restriction, which i feel might be normal. I disconnected my ignition coil and the fuel line to the carb and turned the engine over and PLENTY of fuel seems to be pumping through the pump and into the carb. ive tried to adjust the mixture slightly but still with no luck. With the ignition on but the engine off, when i hit the throttle fuel seems to be spraying into the carb...at least into one barrel. I have heard suggestions pointing towards my dizzy but i am not sure how to check it or what i am looking for. ive also been told i might have to take my carb off and clean it but like i said i am no mechanic and that sounds scary....any help or suggestions would be greatly appreciated..and sorry i dont have a digital camera so i have no pics of this beautiful piece of machinery i am writing about, but hopefully soon! thanks!
