Fuel Smell...Leaking Injector
EDWARDS, CO
Recently, on my 92, I have been smelling raw gas. This morning I did a visual inspection. It appears to be a leak at an injector. With my 1 or 2 :banana: ability, should I try to tackle it? I have the FSM, but still a little intimidated. Is it just a matter of disassembling all of the FI components and then pulling it out and replacing the o- ring? Suggestions? Thanks.
I had to replace my injector, it was leaking from the actual body of the injector. I replaced them all while I was at it. Got rebuilt from my local parts house along with a new intake gasket. It takes a couple hours for a decent wrench. Just make sure you get all the vacuum lines back on, and on the right places.
Thanks MoJ- no fuel smell at the canister.
Brad- Thanks for the input. Its too bad there is not an "easy" way to get to those injectors. When finished, I'll post the outcome. Regards,
DW
