fuel sending unit wires? location...
Hagerstown MD
do these originate fom under the truck then up through the floor? The body is a 78' Any idea as to the color and or stripe assoc.?
thanks Kenn
Yes they do....
Cannot remember the color off the top of my head.
Should be able to find something about it in the Technical links section.
Good luck!
-Steve
My '78 wiring diagram shows the sender to gauge wire as yellow w/ red stripe, sender to ground wire as white w/ black stripe.
HTH, Blake
They're a wrapped pair that comes out of the harness on the right side by the frame rail under the truck. One has an eyelet connector and the other has a white push on for the center terminal of the sender. I don't really remember the colors but it SEEMS like the eyelet ground wire was green.
