fuel sending unit issue
Southern Oregon
My gas gauge will not read above 1/2 tank. If I ground the sending unit wire the gauge will read full, so I beleive the the prob has to be the sender. Any thoughts on repairing it. I would rather put a glass sight window in, then a crappy aftermarket sender.
On that note (my 45's sender is going out, too) I was wondering what the difference between the early and later senders are. SOR lists a break point at 1965 and again in the 1970s. How uncompatable are these? (The 66 and later senders are available from them, New.)
The difference is in the resistance that the circuit has. As long as you have the same sender(read year) as the guage then they work. The guage can be switched out of the cluster easily its just adapting the sender to the older tank.
When I put my TBI in my '62 I had to have a return line. I put in a '78 40 series tank and changed the guage and it reads perfect.
I believe the senders E-1970 are all the same Ohms and will work except the float design is different. Brass instead of plastic. The senders/guages are all marked with the resistance as a value. I.E. '<20'. make sure they match and your good.
Are these no longer available? If they are then finding used might be the ticket. Use this to help find the parts.
