Fuel sender calibration
Massachusetts
Website
www.geocities.com
My 72 FJ40 has a replacement gas tank with an new electric pump and new sender. But my gas gauge is always pointing to 1/2 tank when full. I know there is a way to calibrate the sender but the procedure is unknown to me. Anyone has any idea how to do it or where I can get the instructions?
I Have The Same Problem... People Have Told Me It Could Be A Grounding Issue, But I Havent Found One.
This I know: a +12vdc source need to be applied to the gauge with the sender outside the gas tank. There should be some adjustment either behind or around the gas gauge. With the float in the empty position, with a voltmeter set to ohms check the resistance. It should be like 6 ohms. Then place the float in the full position and repeat measurement. It sholould be around 2.4 ohm. Half tank is around 4 ohm. I will try it tomorrow and post results.
with my gauge I could get it to go from one extreme to the other while it was out of the tank just by moving the float.
are we talking about a poly tank?
My poly reads about 1/8 when its empty, which really pissed my wife off once.:eek:
I was thinking that maybe I could just bend the wire?
anyway the fumes are not very pleasant and I have been considering getting a new metal tank
Most 40 senders I have tested read a resistance of 2 to 18 ohms. 2 being empty... just bend the float arm as needed... although there some aftermarket senders that are not compatible with the 40 gauges due to the difference of the impedance factor....
Mass...
The factory instructions are in manual No. 98154, page 12-26.
