Fuel return line flow
Quick Question about fuel return line-
The way I understand it the fuel return line circulates fuel to keep the fuel from boiling. So the fuel runs relatively constantly back to the tank dependent on how much fuel you're using? 78 2f.
I'm confused about this question and what line you are actually talking
about. There is at least one vapor line (but my 79 doesn't run back to the
tank) and of course there is the carburetor cooler itself which cools things
down after it shuts off (mitigating vapor lock after combustion stops).
Is this line somehow associated with that?
My 78 has a fuel return line that circulates fuel back to the tank under the passenger seat. Runs basically the same path as the supply line with the exception of going through the filter and pump. Shown in the upper left in the attached pic. I just assumed they all did.
Yes, the fuel return is constantly flowing back to the tank. Less so under heavy load when the carb is actually using a little more fuel.
The 79-87 trucks return excess fuel to the tank from the return fitting (3rd hose) at the fuel pump.
Thanks again. You really should start an all things cruiser hotline and charge by the minute. You tend to get right to the heart of the matter.
