Fuel pump woes
BOISE, ID
So I’m not getting fuel to my carb and seems like maybe the lines are clogged or fuel pump went out. No fuel in the filter which if I remember directly usually had more fuel in it. What’s interesting is the truck won’t start now but my fuel gauge all of a sudden seems like it’s working. Not sure why.
You’ve likely fixed this by now...
Is your fuel filter between your fuel tank and your fuel pump?
What fuel pump are you running?
Assuming you have an oem mechanical fuel pump, here are the steps I’d take to resolve this:.
1. Disconnect your fuel feed line, from your carb. Place the end in a container/bottle. Crank the engine for 15 seconds. You should see about a cup of fuel in the container.
2. No fuel in the container... remove and sniff your dipstick... you really don’t want fuel in your crankcase.
3. disconnect the hose from the fuel tank (input) side of the fuel filter. Note: your filter isn’t installed backwards, right?
Is there any fuel coming from the hose?
4. Momentarily disconnect the hose from the fuel feed port on the fuel tank and see if fuel comes out of the tank.
No fuel? Tank is empty... fuel is dirty... fuel pickup is blocked. You can remove the fuel sender and look in the tank. You can unscrew the drain plug and see if fuel drains out.
if there’s fuel in the tank, blow a little air into the tank, thru the feed port... fuel should pour out if the feed port.
5. It can’t hurt to (a) drain the tank. Pull the tank and clean/rehab it. Replace it. (b) disconnect the soft lines from both ends of the hard lines. Blow compressed air thru the hard lines. Squirt carb cleaner into the hard lines. Spray water thru the hard lines. Spray denatured alcohol thru the hard lines. Give it a few minutes to dry any water. (c) replace the soft lines and make sure all clamps are secure.
6. reinstall the fuel filter, being careful to ensure it’s properly oriented.
7. check for a small screen into carb feed inlet... if there, clean it. Reconnect the fuel feed to the carb.
8. Put new fuel in the tank and fire it up.
There are (obviously) potential electrical culprits, if you have an electric fuel pump.
