Hi All!
I suppose this is the reason my engine will only start with starting fluid. Ordered a new fuel pump and sending unit and while waiting for the parts I would like to clean up the tank as there are quite a few particles in the tank as well. The vehicle sat for about two years and was only started occasionally to keep things "Lubed" so I suppose that is when the corrosion happened with a partially empty tank.
Fortunately she did not strand me on the trails but stopped in the driveway. I have been active with her for the last couple of months and there have been no other signs of any issues other than a fuel gauge that reads empty; when I pulled the unit out of the tank I can see why it read empty. And to think I thought it was a stuck fuel float and figured after a couple of trail runs, jiggling and sloshing around, it would fix itself, right? Ha!
My question: What else should I do before installing a new pump, screen, fuel filter and sending unit?
Is it worth dropping the tank and performing a chemical cleaning on it?
Will I have any issues if I install a new pump and filter, drain the tank and refill with fuel only?
What about additives?
I appreciate any and all advice.
Thanks.
Thanks.
