Fuel pump return?
I'm working on a 71 FJ40, i put a 3f carb engine into. On the fuel pump there is a out and in and an extra port, i'm told this port is to prevent vapor lock,
where should i plumb it back into? The vent on a fuel cell or the return? Does fuel actually come out of it?
Brendan
You could just use the 1971 pump & 1987 spacer and ditch the return line.
Or you can run a return line back to the fuel tank. The return will pump liquid fuel back to the tank, so make sure it is a suitable location where liquid fuel will fall down into the tank, and not down through a vent hose to the canister. It can be connected to one of the existing vent/overflow lines, just as long as the line is dumping downhill into the tank.
