Fuel Pump Replacement
Put the old one and the new one next to each other, and make sure that they are the same....lever length, block mounting surface, etc.
Good luck!
-Steve
Yes there is a gasket between the pump and block. New fuel pumps do not come with the gasket, it is a seperate item.
Where are you located?
I would make one out of gasket paper/cereal box/milk carton...
A little Permatex ULTRA black/blue would not hurt...
Good luck!
-Steve
samper said:
Hmm - wouldn't cardboard (cereal box) just dissolve away with time? Always wondered how these paper gaskets lasted ...
I have made MANY gaskets over the years with cereal box and a little black death...Water pump, water outlet, thermostat housing, fuel pump, carb base, and many more on other applications. You make do with what you have when you are working on things in the field from time to time...
Should not be an issue. Post up where you are located if you have not already, someone close may have the gasket....I know I do... :)
Good luck!
-Steve
