Fuel pump rebuilding
Tucson
Is there good source for good rebuild kits? I've seen CCOT's.
The reason being my Nissan Patrol's pump is bad and it is basically the same pump, Kyosan-Denki. I compared it to one of my old Cruiser ones and the internals are the same. Thanks,
-Duane
Is it available from the dealer? 1st Toyota Parts lookup shows a kit for part number 04231-61010. This is for the 1/75-1/79 2F engine. Their price is about $50 for the kit. They also list the complete pump (23100-61011) for $90. I"ve So I'd check you local toyota dealer, cdan at american toyota, 1st toyota...
Depending upon what's bad, I repaired a broken diaphragm on my VW diesel's vacuum pump, by purhasing some valve diaphram material from Orchard supply hardware. The material is essentially rubber sheet with embedded reinforcement. I cut out a new diaphragm and it worked good and lasted for several years and much longer than the aftermarket rebulid kit I purchased. When the aftermarket diaphragm broke, I purchased one from VW. About twice the price, but a much better diaphragm. Of course, a vaccum pump on a VW rabbit (used for brake booster, which you don't really need) is not as important as a fuel pump. I would expect that OEM is the best way to go...
thats some funny @&@&@&@&......I hope you are kiddin! if you don't know.....he has up and vanised with folks money!
tobydog said:
Give Robert at Liquid Off Road a shout. They have all the toy pumps maybe he or his supplier can help you.
Dealers do recognize that FJ40s were made and, at least my dealer, makes it a point to help out with ordering parts for our fine old rigs.
OK, are you guys actually reading through my first post? I'm talking about my NISSAN. Just need some direction to find rebuild parts for Kyosan-Denki pumps.
Thanks Poser, I'll get in touch with Cruiserdan.
-Duane
-Duane
I thought you said the internals were the same and were suggesting that you use a toyota rebuild kit......
