Fuel pump leaking...
MrMoMo
That's not rust, it's Canadian patina...
~Kingston, ON, pero soñando de Panamá
Ok, I did a search came up with a few threads and read them.
I noticed today that there was a fuel smell around my cruiser, looked underneath and found that there had been fuel leaking. I did some poking around and found that it appears to be coming from the fuel pump. Seems that this is not all that uncommon, as I found here on MUD that there is a "weep hole" that may be leaking.
I did manage to put about a 1/16" turn on each of the screws in the top of the fuel pump - incase it is the gasket that is leaking - but it did appear to be coming from the bottom. My question is... I fueled up my landcruiser on Wednesday on my way home. Wednesday night was the last time it ran, and I could actually see fresh drips of fuel coming out of the pump today, (saturday) without the engine having run since wednesday. Why would there still be enough pressure in there to allow fuel to leak out? Or is this "weep hole" on the intake side of the pump?
Everything seemed to be operating fine when I drove it on wednesday, should I expect this pump to give up and leave me stranded at any time soon or am I safe to drive it untill I get a replacement one or parts???
Is it really as easy as it sounds to replace it? :banana:
I see that CCOT has pumps, anyone know of any suppliers other than Toyota -in Canada- that might have these? I hate paying Duty/UPS fees/ etc etc....
Last question... WHY does my cruiser seem to be fine all summer when it is warm, but as soon as it gets nasty out I have to work on it???!?!?!?!??!? :crybaby: :o :mad:
Thanx!
Mo;
There may be rebuilt kit for a '76, I know that for a 1980 one must pay for a new pump. Standard maintenance item.
Murphys law dictates that when weather gets bad, old cruisers start having trouble. Check all electrical grounds.
Mine did the same thing, just went and got a new one from Toyota, if I remember just under 100 bucks, easlily a one :banana: job to replace.
ive rebuild them a really easy job.but most normally i get rid of them and go with electric because ive had the diaframs inside of the pump go bad and leak gas into the motor.my advice if you buy a replacement call cdan or oem from somebody trustworthy.cheap pumps can cause alot of damage
Other than smelling the oil, or holding a flame above the dipstick (removed from cruiser) is there any other way to check for gas in the oil without draining it all? I just did an oil change and really dont want to do it all again unless I have to!
Thanks!
:beer:
Thanks!
no no im not saying ya do have gas in your oil but for me its happened .its just a option if you ever wanted to go to electric you can
Oil does not seem to smell of gas, but may be a little on the thin side... it's definately not over full. There is definately a gas smell around the cruiser and a puddle under it, and I did see fuel dripping from the pump - I'll get a new one.
start with sniffing the oil on the dipstick,yes check the tank and all of the lines,as long as the wire coming of the carb is hooked to a hot wire it will be fine .coil is fine.just dont hook it up to the battery it needs to be hooked to something thats not hot all the time.such the batter, headlights etc.fuse block is fine also:beer:
Well I will chime in, are the connections to the fuel lines and the pump good and snug? I have not heard of fuel leaking externally from the pump before, But then again what do I know. Thats why I question the connections. IIRC there is a hard line going from the pump to the carb, and a partial rubber line from the tank to the pump. Is that rubber line good and is the hose clamp on tight. I though the only real leak on the pump would leak gas into the oil pan. not to the outside. Also is it possible there is a higher fuel line leak somewhere on the system? the pump is at the low spot so it is possibe for fuel to be leaking somewhere else and just running down that hard line to the pump and then getting on the floor. making you think its the pump.. HTH.
As many have said get a new one from Toyota. I just did this about 3 weeks ago. 130 bucks with the new gasket. maybe a 25 minute job.
The leak is definately not from the tank itself, or the lines from it. I visibly saw fuel drip from the bottom of the fuel pump, onto the catch pan. Runs down the catch pan and then drips onto the driveway. I put my fingers on the lines into and out of the pump and they seemed dry. I did try to tighten them as well but they were definately tight. The line that goes up to the carb was also dry at the connection and further up. I am calling toyota on monday to see what it will cost me.
What is involved in this?
Switched wire from ignition, ground and mounting? How much does an electric pump cost and what would be a good one? How much pressure do I need?
What do I do to cover the hole left by the mechanical pump - or should I just leave it in place?
Toyota wants $206Cdn for a pump. - I figure electric must be cheaper than that?
I switched from electric back to the mechanical model last year. I've been very happy with the results. I bought my pump from partsamerica.com (Schucks here) for $33. It is the OEM Kyosan model. The box was rebranded to whatever Schucks parts line is, but upon opening the box it is a Kyosan. It comes with the gaskets, and install is as easy as can be. No problems since doing the install.
:cheers:
:cheers:
Would you happen to have the part#?
Thanks,
Bruce
That's odd, pricing must be done by Zip code, it comes up at $39.88 for me.
Now I just need to find it from someone who will ship to Canada...... :-(
