Fuel pump differences
fort smith, arkansas
Hey guys. Need some help. I’ve got a 67/40 And my fuel pump went out so I ordered a new OEM pump from fjparts. Got it last night and went to install, not the same pump. Similar, but not the same. Base was so thick on the new one I couldn’t even bolt it up. Can anyone tell me if my old pump was maybe wrong, or if they one they sent me is wrong? Thanks. I got it running, by using the parts from the new pump and rebuilding my old one but I hated doing it. Here are pics of both pump, and the internal valves (2 on old and 4 on new)
Top one appear to take the longer bolts if I remember correctly. Other than that should work fine. Cityracer LLC also has fuel pumps, or did.
He doesn’t have any. No one does evidently ha. I ended up using the bottom off my old pump casing, the top and diaphragm out of the new setup, and had to use my old fittings.
While the new pump has four reed valve doesn't look like you can replace them like the old original pump. Personally find nothing wrong using the diaphragm from the new pump in the old housing. Old pump could replace the diaphragm and reed valves pretty easy and cheap years ago. I like it because you can't find this style pump anymore.
While the new pump has four reed valve doesn't look like you can replace them like the old original pump. Personally find nothing wrong using the diaphragm from the new pump in the old housing. Old pump could replace the diaphragm and reed valves pretty easy and cheap years ago. I like it because you can't find this style pump anymore.View attachment 2040072
also the orientation of the inlet on the new pump was offset, so my fuel line is a little stretched now. ill have to find a replacement or make a longer one.
