92 FJ80 (stock everything I think) ran when I parked it.....18 months ago. Now CNS.
I had no spark or Fuel. I fixed the spark by replacing the EFI relay and a 7.5a fuse. Now that I have spark, I don't have fuel. I jumpered the B+ and Fp, but no sound of fuel pumping anywhere. I checked voltage at the pump, and with Key on there are two connectors with voltage, one 12v the other is reading at around 6v. When I re-apply the jumper on B+ an Fp their is a 3rd connector that come up with 12v.
My question is: Is this an obvious fuel pump replacement situation, or is there something going on with the 6v connector. I assume that it has something to do with the high speed/low speed control of the fuel pump, but I just want to be sure.
I already wasted a bunch of money by hiring a "mechanic" to help get it running for me. He had me replace the Coil and the Igniter (ouch!) and when those didn't do it, he was trying to explain that I was going to have to drop the fuel tank to get to the fuel pump and........that's where I hung up on him.....I started reading through the posts this forum after the Igniter didn't work and already knew how to get to the fuel pump. If I had only found this place beforehand, I would have that money to "throw" at the fuel pump....This is a great place for info!!
anyways, is it a new pump I need, or is there something else that could cause it to not kick on, even though it has power all the way to the pump??
