fuel pump buzzing?
I am getting a buzzing noise from the rear of my LX. It seems to have about 3 (maybe 4) tones. At cruise, it's very quiet, when I accelerate, it seems to go to a second speed, if I accelerate harder, it has several different distinct tones/speeds.
I've seen comments that it's the muffler or resonator (my resonator is chopped off), but it could be the muffler, but since it has like 3 or 4 very distinct steps, I'm skeptical. (still going to see if my muffler has rattles)
I'm assuming it's the fuel pump going bad, although at this point, it still runs fine.
Doubt its the fuel pump, it's in the tank, so hard to hear and are very durable. The exhaust is more likely, was an extra hanger added when the resonator was chopped? If not the muffler is prone to cracking from the vibration of the unsupported pipe.
Pumps can get noisier with age, if you had a LR, I would say change it now, it is a classic about to fail noise.
Any difference if you fill the tank with fuel?
Run it very low recently?
Just throwing that out there, some people hear a buzz, some a hum ect.
Rrgards
Dave
Check your O2 sensors. I had one that the nuts came loose (one rotted completely off and the other was small enough the sensor almost fit over it). As I accelerated, I would get exhaust noise. As I let off the accelerator, it got quieter. The harder I pressed, the louder it got.
As I pressed on the gas, the O2 sensor would lift up on the studs until it stopped or relieved enough pressure. When I let off, it fell back into place.
I unscrewed the remains of both nuts, installed a new gasket, and new CS nuts on both studs (with anti-seize) and the noise went away.
i'm in the exhaust noise camp.
Could also be a loose plate in the Cat.
sounds like i need to check the exhaust. That's on the agenda for tonight....
Because it has distinct steps, that sounds like fuel pump to me.
Also, it doesn't change with full vs. empty tank, so that points more to not being the fuel pump.
I didn't add a brace on the resonator. The resonator interfered with the 4x4 labs bumper, so I chopped it off after the axle and put a chrome turn down on it to direct the exhaust down instead of toward the frame. So I guess I should brace it.
I went to check on the muffler... If i tap on the catalytic converters with a rubber mallet, they ring, like they one solid piece (what I would expect), when I tap on the muffler, it almost sounds crunchy. When I tap on it, it doesn't feel like it's an empty can with baffles welded in, it feels like it's full of sand.
When the resonator is removed, the rear mount and vibration dampener goes with it, the next remaining mount is at the muffler. If you shake the end of the pipe up and down and release, will continue the move a few times. Depending on motor rpm, load, this shake, vibration happens when driving, it can destroy the exhaust, usually starting at the front of the muffler. We always add an aftermarket hanger to support, dampen vibration when cutting the resonator off. Don't know if this is the noise, but it will be a problem, been there.
