Fuel neck ... thanks!!
AJP
Would like to thank CruiserDan, ParadiseCruiser and George (of the LED fame) ... I finally got around to replacing my leaking fuel filler neck. Thanks to all how provided the photo's (George) links (Dan), advice (Ron & Dan) and parts (Dan) ... as previously mentioned the POR 15 that I tried to patch the leak with didn't last too long .. but shouldn't complain .. it got me through a couple of months.
The original fuel neck and breather pipe was badly rusted on the top surface from the bracket to the tank.
I sectioned the old pipe to get it out and new pipe just inboard of the frame rail in order to install it and spliced the separated pieces with OEM tank hoses. I also managed to fabricate a support for the outboard piece with the cap, out of a length of flat stainless stock (1") from Home Depot which was twisted in several directions and drilled so that it could be bolted to the tab used by the "dual neck" modification. I secured the upper end of the flat stock to the side of the filler neck just below the cap with a double hose clamp affair mounted on a stainless collar I found at the local Cdn Tire in the plumbing section...seemed like it might work and distribute the pressure a little (what the hell - was worth a try - I had no idea what I was doing anyway!)
Anyway.. used lots of hose clamps and it seems to be holding firm....I am off to fill the tank in a few minutes....if you see a bright flash in the Northern Sky in about 20 minutes.. you will know something went wrong:) Any way THANKS AGAIN Dan Ron George!!
