- Joined
- Feb 21, 2005
- Threads
- 2
- Messages
- 4
I'm installing a rebuilt stock carburator on my 1976 FJ40 to replace the Holley 2300 that the PO had installed. On the rebuilt stock carburator are two inlets for the fuel lines to attach to. My question is which inlet is connected to which supply line? I'm guessing one is some sort of return line but I'm not sure. I have the stock metal supply lines as far as the front of the valve cover but the PO cut them at that point and went to rubber hoses. One of the carburator inlets comes straight out of the carb while the other comes out at a downward angle. Which is the supply fitting and which is the return? Thanks for your help.
