Fuel leak
Texas
I searched for some info on this and found little so I thought I might add this for anyone who sees gas leaking from around their rear axle area. Hopefully anyone running into this problem will find the same issue as I rather than a hole in their tank.
I was at the tire shop getting my new meats installed when the tire guy noticed fuel dribbling onto the ground. I looked with the tire off and could tell that it was one of the lines. I had just filled my tank with some of the cheapest gas I had seen in awhile. Further inspection today confirmed that it was the fuel filler vent line. I did find a little info when I searched that helped.
The fuel filler vent line has a flexible stretch of about 12 inches. Simple fix but it was a challenge to see up in there so here are some photos (it was easier to get the camera in there than my big head). Following are pictures of the worn braided hose & the replacement braided hose (power steering return), the worn braided hose flexed to show holes, the fuel filler hose into tank connection area, and the last picture is of the fuel filler hose clamped to the tank.
I did not replace the fuel filler tube hose yet but it appears as if this is something I will have to do one day soon. There are band claps on both sides.
Good catch and be glad it isnt a hole in your tank ;) That filler line looks about done too, id go ahead and get that on order. If you didnt find it already there is a bracket that holds the filler line (hardline) to the body. Once unbolted the whole filler assembly can be slid back to make getting the lines on easier. Looking from the rear, the left(driver) side bolt hole is notched in the bracket, the passenger side must be removed completely. HTH
Thanks for the heads up on the procedure since it is true that the filler tube flexible section is due to be replaced. I may add some pics to this thread upon completion.
