Fuel leak advice
Maryland
Anybody tangle with this or know the part number? I was getting a fuel smell and was greeted with this when i got under the truck. Any advice is always appreciated. Im trying to dig up a schematic as to what these parts are so a new one can be ordered and swapped in.
Partsouq.com
Plug in your VIN and you can sort through the diagrams to find everything you'll need.
Looks like the fuel filler hardlines rusted out under the clamps.
View attachment 4106317 Anybody tangle with this or know the part number? I was getting a fuel smell and was greeted with this when i got under the truck. Any advice is always appreciated. Im trying to dig up a schematic as to what these parts are so a new one can be ordered and swapped in.
Looks like the fuel filler pipe. 77201-60780
Been there and replaced it. Replacing the filler pipe may seem like an impossible task to thread it through the frame opening. I was able to do that by removing the bolt that secured the small ine to the large one and reattacing it one it was in place. Looking back this job would have been easier if I had greased the pipe so it would slide over the frame openings. If you have rust on the mounting bolts, a mini-induction heater will save lots of frustration.
Those induction heaters are handy! Mind sharing which one you have?
I've had it a couple of years. It gets hot. Then it throws an internal circuit breaker and needs to cool off. A higher quality may not have the problem.
