So- the 40 has been running really good. Lots of power since I went to the electric fan. When I started it to leave work it started acting like it was gasping for fuel (had that lean sound). I still had 7-8lbs of fuel pressure (before the inline filter just before the inlet to the carb). Staring down at the venturis while it is idling, I can only see an ocassional drip of gas. If you rev it up, it shoots fuel in, let off the accelerator and again- a drip or two of gas. I replaced the filter and checked the pressure regulator. Still have the problem.
Here is what I have:
350 V8- Edelbrock 600cfm 4 barrel
Electric Fuel pump just below the tank outlet
Inline fuel pressure gauge- located just before the inline filter (Filter has the return line running out of it)
Adjustable inline regulator (the one with the dial from 1 to 5)
I took the top of the carb off. There was a little gunk in the driver side bowl and on the accelerator pump spring. Cleaned up up a bit, slapped it back together, still runs like crap.
Is there somewhere else I should check on the carb? What do you guys think?
Thanks!
Thanks!
