- Joined
- Aug 5, 2013
- Threads
- 11
- Messages
- 183
I rebuilt my engine and finally finished putting it back in the cruiser and buttoning everything up, now have an electrical problem. I am sure all the wires are hooked up properly and don't see any damage to any parts of the harness and have spent hours double checking everything. The circuit opening relay isn't turning on and because of that the fuel pump relay isn't turning on either. I've tested all the relays in the circuit and all test good, the circuit opening relay gets all the positive connections it's supposed to when I turn on the ignition but the ground that is activated by the ecu doesn't turn on. Is there any condition the ecu needs to see to activate the ground and turn on the opening relay? I don't think the ecu is bad and I never disturbed any wires in the dash so don't think it's something caused during the engine rebuild but am out of ideas, at my wits end so to speak. I'm going on the assumption that the ecu isn't activating the relay for some reason and I hope it's just something simple. Any advice or suggestions at this point would be most appreciated.
