FSM rear door window page
I have been trying to replace my rear window rubber channels, I did the front, but am having difficulty with the back. I have the Max Ellerys repair manual which gives good direction for the front as does another post on this site, but I cannot find any direction for the rear window. The repair manual I have states to see the front door removal directions but obviously it is not the same. I have tried to download the fsm from toyota but because I am from Canada I cannot pay and get access. I have not found a TIS for Canada
Could somebody send me just the page or give me a quck how to on removing the window, I have everything apart, but have not been able to figure out the window removal part.
Thanks
hi
sorry I can't help with the request...can you help me with the replacement of the rear door cylinders? I have a 94 FJ80 and it was easy to remove the old cylinders from the vehicle, but removing the cylinders from the brackets is another story. I just wondered if you had any experience with this.
thanks
Kbuckley
Poor Puddles... :frown: :lol:
Ok, ok: So how far into the door are you? My FSM ('91) says the rubber channel comes out *without* having to remove the glass, or even the divider between the main window and the quarter window.
Tell me where you're at and I'll see if I can talk you through it.
Curtis
Puddles,
The Toyota FSM is not much help.
Beo,
I'm pretty sure he means the second row door/window. Don't suppose you want to post the couple pages of instructions after the blow-up pic of those? If not, I'll walk him through as promised.
Curtis
Thank CJF and Beo,
I am talking about the second row door. I have pulled the interior panel of the door off, and I have access to the entire interior of the door. I have not pulled off the entire plastic barier. So essentially that is where I am at. On the front there were two bolts that needed to be taken out then the window pulled out, no problem, but in my manual for removal of this window it says to follow these intstructions but there is not two bolts holding the window into the the regulator as in the front at least not that I can see. Also the parts diagram does not show the bolts as it does for the front so I am now stuck.
Thanks in advance for the help.
Window = glass?
Like I said, according to the FSM the glass doesn't even need to come out: You just pull the channel out, starting from the top. (I take it it's "L" shaped?) Edit: Whoops; I meant (upside down) "U" shaped.
Keep me posted,
Curtis
I am a little lost. I am talking about the rubber that fits into the window channel. The glass then slides up inside the ruber. I do not see how it is possible to pull the rubber out with the window still in place, because at every point through the entire up down of the window, the window is still in the rubber, so it would be virtually impossible to replace the rubber with the window still in the door. Either I am not explaining it very well or I am missing something completly.
The rubber replacement that fits in the window channel is shaped more like an upside down U. Both sides of the door and the top of the door have the rubber run which is one piece.
Thanks
Thanks CJF, I PMed Johnheld about this.
With respect to the window all the way down, I might be able to pull it out but I dont think it would be possible to reinstall it, I will take a look again.
thanks
