- Joined
- Oct 12, 2009
- Threads
- 26
- Messages
- 201
- Location
- Overland Park, Kansas
- Website
- www.guardianml.com
Hey all, maybe someone can help me out until my FSM comes in from Toyota Publications. It's been on backorder since November and is supposedly being shipped 2/18...
I wanty to change the tranny fluid and the transfer case oil on my '97 LX 450 - never done either before. The following is from the FAQ and it sufficiently stumped me regarding the transmission's actual capacity (need to know how many quarts to buy before I do it):
Transmission
11.0 liters (11.6 US qts, 9.7 lmp. qts)
1.9 liters (2.0 US qts, 1.7 lmp. qts)
ATF DEXRON®II
I don't understand why the two volumes? So my question - does the tranny have a filter such that I need to remove the pan to replace the filter and how many quarts should I buy so I am prepared? I am assuming 12 QTs?
On the transfer case, not having a picture to reference in the FSM causes me to doubt I have correctly identified the drain plug and the fill plug.
Is the drain plug on the transfer case located above the skid plate on the bottom of the case at the very rearward most point of the transfer case? Is the fill plug about one third of the way up the transfer case at about the eight o'clock position as you look forward, and located on the rear vertical side of the transfer case?
I hope I am making sense. Since MUD is not currently allowing pictures to be loaded (at least based on my experience yesterday and based on the reporting in "Oddities" I've read), I can't take a picture of the transfer case to demonstrate what I am trying to describe.
Thanks for any help you guys can provide.
Regards,
Kirk
Transmission
ATF DEXRON®II
Regards,
Kirk
