- Location
- United States
Folks I just bought this off ebay to replace my carb, on my 65 f250. I finally got it tuned right so I really don't need the kit. All is there to hook it up to a FE block. I bought a blocking plate and O2 bung. This is a closed loop system running off an O2 sensor. Ill have this up for a few days untill I decide to put it on my ford anyway.
It even comes with a laptop fer playing.
$900 shipped.
Here is the auction add when I bought it:
Up for auction is a 900 CFM holley projection 4DI unit part number 504-21 in great shape that I bought used off ebay a couple years ago and I personally never installed, well most of it anyways. I did use the 4DI CPU for a little while on my car that has the 4d setup and can verify that it works just fine(and if you have a 4d system this 4DI computer plugs right into that harness and is the only difference for a quick upgrade). I Never tried the throttle body but I did disassemble it, clean it and replace the o-rings in the upper fuel injector pod. Everything appears to be in great shape and the Throttle body looks like new again. The wire harness is in great shape, it will need a couple of wires lengthened like the one that goes to the fuel pump and the main power wire but thats normal anyways. The kit is mostly complete except for a few minor things like the smaller fuel filter and a carb base gasket and various small screws and vacuum caps that can be easily replaced at an auto or hardware store. There is also an air cleaner spacer that goes between the top of the tbi and the bottom of the air cleaner. The one included is a metal one off of some factory tbi and it may be too tall as the one that came with it is about half the height, it may also be fine depending on how much hood clearance you have. Its not a big deal though as the spacer can be found at most auto parts stores as well or you can get the actual holley one from summit for not too much if you want to. (summit also carries pretty much any part you may want and there is a parts list included with all the part numbers to make it very easy but like I said only small common things are missing and you shouldn't need to order anything to make this work). The kit includes the used fuel pump that I didn't test but looks to be in good shape, a brand new holley oxygen sensor(a $66 value) and a new weld in bung. The temp sensor and map sensor are there but untested, should be fine. I have upgraded the 4DI cpu to the newest software and chip version($105 value) so you can use datalogging software and autochart-pro, a nice alternate aftermarket programming software that can do a pretty cool auto-tune feature, which is also included. I am also including an older compaq presario 1030 laptop computer and carrying case with windows 95 that already has all of the software installed on it, but has a bad battery. It does work fine when plugged in though, and it comes with a car power adaptor as well but im not sure how well it works running off that. I would suggest a new battery to make things easier. Included with the laptop is a male to female adaptor for the serial plug to fit into it correctly. This is no power house laptop obviously but is just fine for using with this system. The label on the Holley 4DI box reads as follows:
504-21 4 BBL DIGITAL INTERACTIVE FUEL INJECTION SYSTEM FOR 350-500 HORSEPOWER V-8 NON-COMPUTERIZED ENGINES. 900 CFM, 4 BBL. THROTTLE BODY WITH (4) 85PPH INJECTORS. IBM COMPATIBLE, PC PREOGRAMMABLE FOR FUEL AND IGNITION CONTROL. FITS MOST 4 BBL. STOCK AND AFTERMARKET AIR CLEANER SYSTEMS. INCLUDES: 4 BBL. TBI ASSEMBLY, DIGITAL ELECTRONIC CONTROL UNIT, 410 GPH ELECTRIC FUEL PUMP, COMPLETE WIRING HARNESS, SENSORS FOR COOLANT TEMP MAP OXYGEN AND AIRCHARGE TEMP. THROTTLE POSITION AND AN IDLE AIR CONTROL MOTOR. 3 1/2" SOFTWARE DISKETTES, MOUNTING HARDWARE AND LINKAGE CONNECTIONS(some now missing but easily replaced at auto store) EASY TO FOLLOW INSTRUCTIONS. GM KNOCK SENSOR COMPATIBLE. REQUIRES P/N 20-98 BRACKET FOR USE WITH GM TH700R-4 TRANSMISSIONS. NOT COMPATIBLE WITH OTHER AOD TRANSMISSIONS. REQUIRES GM OR FORD 7 WIRE DISTRIBUTOR FOR IGNITION CONTROL. NOT LEGAL FOR SALE OR USE ON CALIFORNIA POLLUTION CONTROLLED MOTOR VEHICLES.
Similar kits like this sell for $1500 new, my reserve is half of that and includes a laptop and extra software. Any questions feel free to ask, and good luck bidding!
I have more pics if needed
thanks,
bob
http://www.ford-trucks.com/classifieds/data/29/large/9d9f_1.JPG
$900 shipped.
thanks,
bob
